소개
This guide will help you disassemble the top half of the phone. By completing this you will have access to the display connections and hinge.
부품
지정된 부품이 없습니다.
Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
You should notice that the number pad is loose and can simply be taken out of the open phone casing.
Remove the four rubber covers from the front screen using a metal spudger.
거의 끝나갑니다!
결론
