이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will help you disassemble the top half of the phone. By completing this you will have access to the display connections and hinge.
필요한 것
Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
You should notice that the number pad is loose and can simply be taken out of the open phone casing.
Remove the four rubber covers from the front screen using a metal spudger.
거의 끝나갑니다!
결론
