주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG CU515 Keypad Replacement
필요한 것
  1. LG CU515 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG CU515 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Keypad Replacement: 2 단계, 이미지 3개 중 1개 LG CU515 Keypad Replacement: 2 단계, 이미지 3개 중 2개 LG CU515 Keypad Replacement: 2 단계, 이미지 3개 중 3개
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Keypad Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Keypad Replacement: 4 단계, 이미지 1개 중 1개
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Keypad Replacement: 5 단계, 이미지 3개 중 1개 LG CU515 Keypad Replacement: 5 단계, 이미지 3개 중 2개 LG CU515 Keypad Replacement: 5 단계, 이미지 3개 중 3개
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Keypad Replacement: 6 단계, 이미지 1개 중 1개
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Keypad Replacement: 8 단계, 이미지 1개 중 1개
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
  9. LG CU515 Keypad Replacement, Keypad: 9 단계, 이미지 1개 중 1개
    • Push keypad up and out of the phone casing until they separate.
    • Replace with new keypad.
결론
작성자
6다른 기여자 명과 함께
Zack Mintzer
회원 가입일: 04/16/13
1 평판
안내서 6개를 작성함
Cal Poly, Team 21-55, Johann Spring 2013 Cal Poly, Team 21-55, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G55
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 60
전체 시간: 431
