주요 콘텐츠로 건너뛰기
LG CU515 SKU 64743 Device Camera Lens Replacement
필요한 것
  1. 주의: 1-5 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    LG CU515 SKU 64743 Device Camera Lens Replacement, Front Cover: 1 단계, 이미지 1/2 LG CU515 SKU 64743 Device Camera Lens Replacement, Front Cover: 1 단계, 이미지 2/2
    • Separate the top half of the clamshell from the bottom half by first locating the two hinges.
    • Carefully pull to one side and immediately up. The top part should pop out of the hinge. Next slide the opposite direction to pull out of the other hinge.
    • This will take a lot of force, so be careful not to break the plastic hinge.
  2. LG CU515 SKU 64743 Device Camera Lens Replacement: 2 단계, 이미지 1/3 LG CU515 SKU 64743 Device Camera Lens Replacement: 2 단계, 이미지 2/3 LG CU515 SKU 64743 Device Camera Lens Replacement: 2 단계, 이미지 3/3
    • Locate the two small circles located at the bottom left and right corners of the main screen.
    • Remove the two small rubber dots covering the screw heads using the tweezers.
    • The sharp ends of the tweezers can be stuck into the rubber dots in order to remove them.
  3. LG CU515 SKU 64743 Device Camera Lens Replacement: 3 단계, 이미지 1/3 LG CU515 SKU 64743 Device Camera Lens Replacement: 3 단계, 이미지 2/3 LG CU515 SKU 64743 Device Camera Lens Replacement: 3 단계, 이미지 3/3
    • Locate the rubber strip found above the main screen. Use the pry bar to remove the rubber strip. This exposes the screws in the upper left and right hand corner.
  4. LG CU515 SKU 64743 Device Camera Lens Replacement: 4 단계, 이미지 1/2 LG CU515 SKU 64743 Device Camera Lens Replacement: 4 단계, 이미지 2/2
    • Use the small Phillips-head screwdriver to remove four 3mm screws exposed during steps 1 and 2.
  5. LG CU515 SKU 64743 Device Camera Lens Replacement: 5 단계, 이미지 1/3 LG CU515 SKU 64743 Device Camera Lens Replacement: 5 단계, 이미지 2/3 LG CU515 SKU 64743 Device Camera Lens Replacement: 5 단계, 이미지 3/3
    • Using the pry bar, remove the front cover of the phone.
    • It may be necessary to run the pry bar along the length of the perimeter to separate the front cover from the rest of the phone.
    • Once loose, the front cover should easily be pulled away from the phone, as shown in the second picture.
  6. LG CU515 SKU 64743 Device Camera Lens Replacement, Camera Lens: 6 단계, 이미지 1/3 LG CU515 SKU 64743 Device Camera Lens Replacement, Camera Lens: 6 단계, 이미지 2/3 LG CU515 SKU 64743 Device Camera Lens Replacement, Camera Lens: 6 단계, 이미지 3/3
    • Rotate the phone 180 degrees and locate the small black square shown in the photo. Using the tweezers, pinch the raised circular lens casing and remove.
결론
Maggie
회원 가입일: 10/18/13
680 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 287
