주요 콘텐츠로 건너뛰기
LG CU515 SKU 64743 Device Mother Board Replacement
필요한 것
  1. LG CU515 SKU 64743 Device Mother Board Replacement, Back Cover: 1 단계, 이미지 1/3 LG CU515 SKU 64743 Device Mother Board Replacement, Back Cover: 1 단계, 이미지 2/3 LG CU515 SKU 64743 Device Mother Board Replacement, Back Cover: 1 단계, 이미지 3/3
    • Locate the raised tab at the top of the back cover.
    • Holding the phone in one hand and using your thumb on your other hand, push down on the tab until the cover detaches from the phone.
    • Slide the cover down until it is completely removed from the phone.
  2. 주의: 2 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    LG CU515 SKU 64743 Device Mother Board Replacement, Battery: 2 단계, 이미지 1/3 LG CU515 SKU 64743 Device Mother Board Replacement, Battery: 2 단계, 이미지 2/3 LG CU515 SKU 64743 Device Mother Board Replacement, Battery: 2 단계, 이미지 3/3
    • Holding the phone in one hand and using your index finger on your other hand, remove the battery from the phone by prying it out at indention located at the bottom of the phone.
  3. LG CU515 SKU 64743 Device Mother Board Replacement, Mother Board: 3 단계, 이미지 1/3 LG CU515 SKU 64743 Device Mother Board Replacement, Mother Board: 3 단계, 이미지 2/3 LG CU515 SKU 64743 Device Mother Board Replacement, Mother Board: 3 단계, 이미지 3/3
    • Using a spudger or other sharp tool, remove the two rubber pieces on the top of the back of the phone.
  4. LG CU515 SKU 64743 Device Mother Board Replacement: 4 단계, 이미지 1/2 LG CU515 SKU 64743 Device Mother Board Replacement: 4 단계, 이미지 2/2
    • Use a small Phillips head screwdriver to remove the six 3mm screws identified in the photo.
  5. LG CU515 SKU 64743 Device Mother Board Replacement: 5 단계, 이미지 1/2 LG CU515 SKU 64743 Device Mother Board Replacement: 5 단계, 이미지 2/2
    • Using a pry bar or flat headed screw driver, pry the back cover from the front and lowly lift apart.
    • It may be necessary to pry around the entire edge in order to remove the back cover.
  6. LG CU515 SKU 64743 Device Mother Board Replacement: 6 단계, 이미지 1/2 LG CU515 SKU 64743 Device Mother Board Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to carefully unplug the wires connecting the speakers to the mother board.
  7. LG CU515 SKU 64743 Device Mother Board Replacement: 7 단계, 이미지 1/3 LG CU515 SKU 64743 Device Mother Board Replacement: 7 단계, 이미지 2/3 LG CU515 SKU 64743 Device Mother Board Replacement: 7 단계, 이미지 3/3
    • Locate the small tab located at the top, center of the motherboard. It connects the motherboard to the rest of the phone. Detach it using the tweezers.
    • Carefully unplug the rectangular ribbon cable connection using tweezers.
    • It should now be possible to lift the motherboard from the rest of the phone.
결론
Maggie
회원 가입일: 10/18/13
680 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 262
