주요 콘텐츠로 건너뛰기
LG CU515 Speaker Replacement
필요한 것
  1. LG CU515 Speaker Replacement, Battery: 1 단계, 이미지 1/2 LG CU515 Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Speaker Replacement: 2 단계, 이미지 1/3 LG CU515 Speaker Replacement: 2 단계, 이미지 2/3 LG CU515 Speaker Replacement: 2 단계, 이미지 3/3
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Speaker Replacement, Motherboard: 3 단계, 이미지 1/1
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Speaker Replacement: 4 단계, 이미지 1/1
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Speaker Replacement: 5 단계, 이미지 1/3 LG CU515 Speaker Replacement: 5 단계, 이미지 2/3 LG CU515 Speaker Replacement: 5 단계, 이미지 3/3
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Speaker Replacement: 6 단계, 이미지 1/1
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Speaker Replacement: 8 단계, 이미지 1/1
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
  9. LG CU515 Speaker Replacement, Speaker: 9 단계, 이미지 1/2 LG CU515 Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Remove the speaker component from the back of the phone by lifting up the top part to a 45 degree angle and pulling it out.
  10. LG CU515 Speaker Replacement: 10 단계, 이미지 1/1
    • Pull speaker out of the component by grabbing the wire attached to it in order to replace it.
결론
Zack Mintzer
회원 가입일: 04/16/13
1 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-55, Johann Spring 2013 Cal Poly, Team 21-55, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G55
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 14
전체 시간: 358
