주요 콘텐츠로 건너뛰기
LG Chocolate 3 Front Faceplate Replacement
필요한 것
  1. LG Chocolate 3 Front Faceplate Replacement, Front Faceplate: 1 단계, 이미지 1/1
    • Use the plastic opening tool to lift the front faceplate from the device.
    • The faceplate has adhesive in multiple areas. Loosen the faceplate around all of the edges first to make it easier to remove.
  2. LG Chocolate 3 Front Faceplate Replacement: 2 단계, 이미지 1/1
    • The scroll wheel has an orange display data cable attached which may rip from excessive force.
    • Lift the front faceplate up gently.
  3. LG Chocolate 3 Front Faceplate Replacement: 3 단계, 이미지 1/1
    • Be careful not to rip the orange display data cable or drop the scroll wheel on the LCD screen.
    • Use the flat end of the spudger to pry the scroll wheel from the faceplate.
  4. LG Chocolate 3 Front Faceplate Replacement: 4 단계, 이미지 1/2 LG Chocolate 3 Front Faceplate Replacement: 4 단계, 이미지 2/2
    • Separate the front faceplate from the device completely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brenna Yagade
회원 가입일: 04/15/13
40 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G35
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 292
