주요 콘텐츠로 건너뛰기
LG Chocolate 3 Rear Case Replacement
필요한 것
  1. LG Chocolate 3 Rear Case Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the phone off before starting the replacement process.
    • Place the phone face down.
    • Press your finger down on the indentation and slide the back plate off.
  2. LG Chocolate 3 Rear Case Replacement: 2 단계, 이미지 1/3 LG Chocolate 3 Rear Case Replacement: 2 단계, 이미지 2/3 LG Chocolate 3 Rear Case Replacement: 2 단계, 이미지 3/3
    • Using your index finger lift and remove the battery from the phone.
  3. LG Chocolate 3 Rear Case Replacement, Rear Case: 3 단계, 이미지 1/1
    • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
    • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
  4. LG Chocolate 3 Rear Case Replacement: 4 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
    • If needed, use tweezers to remove loose screws from the recessed holes.
    • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
  5. LG Chocolate 3 Rear Case Replacement: 5 단계, 이미지 1/2 LG Chocolate 3 Rear Case Replacement: 5 단계, 이미지 2/2
    • Pull the rear case up using the spudger.
    • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
    • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
  6. LG Chocolate 3 Rear Case Replacement: 6 단계, 이미지 1/1
    • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
  7. LG Chocolate 3 Rear Case Replacement: 7 단계, 이미지 1/2 LG Chocolate 3 Rear Case Replacement: 7 단계, 이미지 2/2
    • Carefully remove the rear case from the phone.
결론
Brenna Yagade
회원 가입일: 04/15/13
40 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-35, Amido Spring 2013 Cal Poly, Team 12-35, Amido Spring 2013 회원
CPSU-AMIDO-S13S12G35
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 287
