주요 콘텐츠로 건너뛰기
LG Chocolate Keypad Replacement
필요한 것
  1. LG Chocolate Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Keypad Replacement, Back Cover: 2 단계, 이미지 1개 중 1개
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Keypad Replacement: 3 단계, 이미지 3개 중 1개 LG Chocolate Keypad Replacement: 3 단계, 이미지 3개 중 2개 LG Chocolate Keypad Replacement: 3 단계, 이미지 3개 중 3개
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate Keypad Replacement, Sliding Front: 4 단계, 이미지 1개 중 1개
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Keypad Replacement: 5 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement: 5 단계, 이미지 2개 중 2개
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Keypad Replacement: 6 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement: 6 단계, 이미지 2개 중 2개
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Keypad Replacement, LCD Board: 8 단계, 이미지 3개 중 1개 LG Chocolate Keypad Replacement, LCD Board: 8 단계, 이미지 3개 중 2개 LG Chocolate Keypad Replacement, LCD Board: 8 단계, 이미지 3개 중 3개
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Keypad Replacement: 9 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement: 9 단계, 이미지 2개 중 2개
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Keypad Replacement: 10 단계, 이미지 1개 중 1개
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Keypad Replacement: 11 단계, 이미지 1개 중 1개
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Keypad Replacement: 12 단계, 이미지 2개 중 1개 LG Chocolate Keypad Replacement: 12 단계, 이미지 2개 중 2개
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Keypad Replacement, LCD Screen: 13 단계, 이미지 1개 중 1개
    • The LCD screen is no longer connected to the LCD board.
  14. LG Chocolate Keypad Replacement, Keypad: 14 단계, 이미지 1개 중 1개
    • Push the keypad out from the front of the phone and remove it.
결론
작성자
5다른 기여자 명과 함께
Maci Miri
회원 가입일: 01/18/13
39 평판
안내서 3개를 작성함
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 회원
CPSU-REGAN-W13S19G46
4 회원들
안내서 22개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 21
전체 시간: 377
