주요 콘텐츠로 건너뛰기
LG Chocolate Motherboard Replacement
필요한 것
  1. LG Chocolate Motherboard Replacement, Battery: 1 단계, 이미지 1/2 LG Chocolate Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Motherboard Replacement, Back Cover: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Motherboard Replacement: 3 단계, 이미지 1/3 LG Chocolate Motherboard Replacement: 3 단계, 이미지 2/3 LG Chocolate Motherboard Replacement: 3 단계, 이미지 3/3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Motherboard Replacement, Motherboard: 4 단계, 이미지 1/2 LG Chocolate Motherboard Replacement, Motherboard: 4 단계, 이미지 2/2
    • Carefully pry the motherboard off of the back case
결론
Maci Miri
회원 가입일: 01/18/13
39 평판
안내서 3개 작성하였습니다
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 회원
CPSU-REGAN-W13S19G46
4 회원들
안내서 22개 작성하였습니다
댓글 한 개
is there any way to get information off of a motherboard with a chargeport that is broken?
Robert Gietzen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 14
전체 시간: 803
