주요 콘텐츠로 건너뛰기
LG Chocolate Side Buttons Replacement
필요한 것
  1. LG Chocolate Side Buttons Replacement, Battery: 1 단계, 이미지 1/2 LG Chocolate Side Buttons Replacement, Battery: 1 단계, 이미지 2/2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Side Buttons Replacement, Back Cover: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Side Buttons Replacement: 3 단계, 이미지 1/3 LG Chocolate Side Buttons Replacement: 3 단계, 이미지 2/3 LG Chocolate Side Buttons Replacement: 3 단계, 이미지 3/3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Side Buttons Replacement, Sliding Front: 4 단계, 이미지 1/1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Side Buttons Replacement: 5 단계, 이미지 1/2 LG Chocolate Side Buttons Replacement: 5 단계, 이미지 2/2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Side Buttons Replacement: 6 단계, 이미지 1/2 LG Chocolate Side Buttons Replacement: 6 단계, 이미지 2/2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Side Buttons Replacement: 7 단계, 이미지 1/1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Side Buttons Replacement, LCD Board: 8 단계, 이미지 1/3 LG Chocolate Side Buttons Replacement, LCD Board: 8 단계, 이미지 2/3 LG Chocolate Side Buttons Replacement, LCD Board: 8 단계, 이미지 3/3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Side Buttons Replacement: 9 단계, 이미지 1/2 LG Chocolate Side Buttons Replacement: 9 단계, 이미지 2/2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Side Buttons Replacement: 10 단계, 이미지 1/1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Side Buttons Replacement: 11 단계, 이미지 1/1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Side Buttons Replacement: 12 단계, 이미지 1/2 LG Chocolate Side Buttons Replacement: 12 단계, 이미지 2/2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Side Buttons Replacement, Side Buttons: 13 단계, 이미지 1/1
    • The side buttons can now be accessed freely.
결론
Charles Yoon
회원 가입일: 01/18/13
64 평판
안내서 2개 작성하였습니다
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013 회원
CPSU-REGAN-W13S19G46
4 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 190
