주요 콘텐츠로 건너뛰기
LG Cookie Fresh Disassembly
필요한 것
  1. LG Cookie Fresh Disassembly, LG Cookie Fresh Disassembly: 1 단계, 이미지 1/2 LG Cookie Fresh Disassembly, LG Cookie Fresh Disassembly: 1 단계, 이미지 2/2
    • Push up the back panel with both of your thumbs.
    • While pushing up with both thumbs, be sure to apply gentle pressure in order to unclip the backplate off of the device.
    • Be careful not to push down too hard or you may crack the backplate or damage the internal components of the device.
  2. LG Cookie Fresh Disassembly: 2 단계, 이미지 1/1
    • Unscrew all of the visible screws.
  3. LG Cookie Fresh Disassembly: 3 단계, 이미지 1/3 LG Cookie Fresh Disassembly: 3 단계, 이미지 2/3 LG Cookie Fresh Disassembly: 3 단계, 이미지 3/3
    • Take a spudger (or something strong but not sharp) to wedge between the device and the backplate.
    • Be careful when prying open the device, you don't want to damage any clips or wires that are inside.
  4. LG Cookie Fresh Disassembly: 4 단계, 이미지 1/3 LG Cookie Fresh Disassembly: 4 단계, 이미지 2/3 LG Cookie Fresh Disassembly: 4 단계, 이미지 3/3
    • Unplug the cable and lift the motherboard.
  5. LG Cookie Fresh Disassembly: 5 단계, 이미지 1/3 LG Cookie Fresh Disassembly: 5 단계, 이미지 2/3 LG Cookie Fresh Disassembly: 5 단계, 이미지 3/3
    • Push the buttons out from the back and peel the front.
결론
Razvan Mirescu
회원 가입일: 05/26/22
392 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 66
