주요 콘텐츠로 건너뛰기
LG Cosmos 2 Option Buttons Replacement
필요한 것
  1. LG Cosmos 2 Option Buttons Replacement, Battery: 1 단계, 이미지 1/3 LG Cosmos 2 Option Buttons Replacement, Battery: 1 단계, 이미지 2/3 LG Cosmos 2 Option Buttons Replacement, Battery: 1 단계, 이미지 3/3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Option Buttons Replacement: 2 단계, 이미지 1/3 LG Cosmos 2 Option Buttons Replacement: 2 단계, 이미지 2/3 LG Cosmos 2 Option Buttons Replacement: 2 단계, 이미지 3/3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Option Buttons Replacement, Rear Case: 3 단계, 이미지 1/1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Option Buttons Replacement: 4 단계, 이미지 1/3 LG Cosmos 2 Option Buttons Replacement: 4 단계, 이미지 2/3 LG Cosmos 2 Option Buttons Replacement: 4 단계, 이미지 3/3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 Option Buttons Replacement, Motherboard: 5 단계, 이미지 1/1
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 Option Buttons Replacement: 6 단계, 이미지 1/1
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 Option Buttons Replacement: 7 단계, 이미지 1/2 LG Cosmos 2 Option Buttons Replacement: 7 단계, 이미지 2/2
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 Option Buttons Replacement: 8 단계, 이미지 1/2 LG Cosmos 2 Option Buttons Replacement: 8 단계, 이미지 2/2
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 Option Buttons Replacement: 9 단계, 이미지 1/1
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 Option Buttons Replacement, Option Buttons: 10 단계, 이미지 1/1
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  11. LG Cosmos 2 Option Buttons Replacement: 11 단계, 이미지 1/2 LG Cosmos 2 Option Buttons Replacement: 11 단계, 이미지 2/2
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  12. LG Cosmos 2 Option Buttons Replacement: 12 단계, 이미지 1/1
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  13. LG Cosmos 2 Option Buttons Replacement: 13 단계, 이미지 1/2 LG Cosmos 2 Option Buttons Replacement: 13 단계, 이미지 2/2
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  14. LG Cosmos 2 Option Buttons Replacement: 14 단계, 이미지 1/1
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  15. LG Cosmos 2 Option Buttons Replacement: 15 단계, 이미지 1/1
    • Detach the ribbon cable with the plastic opener.
  16. LG Cosmos 2 Option Buttons Replacement: 16 단계, 이미지 1/3 LG Cosmos 2 Option Buttons Replacement: 16 단계, 이미지 2/3 LG Cosmos 2 Option Buttons Replacement: 16 단계, 이미지 3/3
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  17. LG Cosmos 2 Option Buttons Replacement: 17 단계, 이미지 1/1
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
결론
Nick White
회원 가입일: 10/18/13
851 평판
안내서 8개 작성하였습니다
Clemson, Team 13-1, Benson Fall 2013 Clemson, Team 13-1, Benson Fall 2013 회원
CLEM-BENSON-F13S13G1
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 354
