주요 콘텐츠로 건너뛰기
LG Cosmos 2 Rear Case Replacement
필요한 것
  1. LG Cosmos 2 Rear Case Replacement, Battery: 1 단계, 이미지 1/3 LG Cosmos 2 Rear Case Replacement, Battery: 1 단계, 이미지 2/3 LG Cosmos 2 Rear Case Replacement, Battery: 1 단계, 이미지 3/3
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 Rear Case Replacement: 2 단계, 이미지 1/3 LG Cosmos 2 Rear Case Replacement: 2 단계, 이미지 2/3 LG Cosmos 2 Rear Case Replacement: 2 단계, 이미지 3/3
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 Rear Case Replacement, Rear Case: 3 단계, 이미지 1/1
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 Rear Case Replacement: 4 단계, 이미지 1/3 LG Cosmos 2 Rear Case Replacement: 4 단계, 이미지 2/3 LG Cosmos 2 Rear Case Replacement: 4 단계, 이미지 3/3
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
결론
Nick White
회원 가입일: 10/18/13
851 평판
안내서 8개 작성하였습니다
Clemson, Team 13-1, Benson Fall 2013 Clemson, Team 13-1, Benson Fall 2013 회원
CLEM-BENSON-F13S13G1
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 275
