주요 콘텐츠로 건너뛰기
LG Cosmos Motherboard Replacement
필요한 것
  1. LG Cosmos Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Motherboard Replacement: 2 단계, 이미지 1/1
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Motherboard Replacement, Rear Case: 3 단계, 이미지 1/1
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Motherboard Replacement: 5 단계, 이미지 1/1
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Motherboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Motherboard Replacement: 7 단계, 이미지 1/1
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Motherboard Replacement: 8 단계, 이미지 1/1
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Motherboard Replacement: 9 단계, 이미지 1/1
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Motherboard Replacement: 10 단계, 이미지 1/1
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Motherboard Replacement: 11 단계, 이미지 1/1
    • Pull the motherboard away from the rest of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Johnny Phane
회원 가입일: 04/15/13
70 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-63, Johann Spring 2013 Cal Poly, Team 13-63, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G63
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 16
전체 시간: 1,874
