주요 콘텐츠로 건너뛰기
LG Cosmos Silicon Keypad Replacement
필요한 것
  1. LG Cosmos Silicon Keypad Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Silicon Keypad Replacement: 2 단계, 이미지 1개 중 1개
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Silicon Keypad Replacement, Rear Case: 3 단계, 이미지 1개 중 1개
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Silicon Keypad Replacement: 4 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Silicon Keypad Replacement: 5 단계, 이미지 1개 중 1개
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Silicon Keypad Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Silicon Keypad Replacement: 7 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Silicon Keypad Replacement: 8 단계, 이미지 1개 중 1개
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Silicon Keypad Replacement: 9 단계, 이미지 1개 중 1개
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Silicon Keypad Replacement: 10 단계, 이미지 1개 중 1개
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Silicon Keypad Replacement: 11 단계, 이미지 1개 중 1개
    • Pull the motherboard away from the rest of the phone.
  12. LG Cosmos Silicon Keypad Replacement, Silicon Keypad: 12 단계, 이미지 1개 중 1개
    • Lift the silicon keypad away from the rest of the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Johnny Phane
회원 가입일: 04/15/13
91 평판
안내서 5개를 작성함
Cal Poly, Team 13-63, Johann Spring 2013 Cal Poly, Team 13-63, Johann Spring 2013 회원
CPSU-JOHANN-S13S13G63
3 회원들
안내서 14개를 작성함
1가이드 댓글
Steps 10 and 11 are not necessary for replacing just the silicone keypad. As long as you are careful not to pull on the motherboard, once you have the motherboard rotated up, you are able to replace the silicone keypad directly from that point.
Randy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 14
전체 시간: 959
