주요 콘텐츠로 건너뛰기
LG Dare Logic Board Replacement
필요한 것
  1. LG Dare Logic Board Replacement, Battery: 1 단계, 이미지 1/2 LG Dare Logic Board Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
  2. LG Dare Logic Board Replacement: 2 단계, 이미지 1/3 LG Dare Logic Board Replacement: 2 단계, 이미지 2/3 LG Dare Logic Board Replacement: 2 단계, 이미지 3/3
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
  3. LG Dare Logic Board Replacement, Logic Board: 3 단계, 이미지 1/2 LG Dare Logic Board Replacement, Logic Board: 3 단계, 이미지 2/2
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
  4. LG Dare Logic Board Replacement: 4 단계, 이미지 1/3 LG Dare Logic Board Replacement: 4 단계, 이미지 2/3 LG Dare Logic Board Replacement: 4 단계, 이미지 3/3
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
  5. LG Dare Logic Board Replacement: 5 단계, 이미지 1/3 LG Dare Logic Board Replacement: 5 단계, 이미지 2/3 LG Dare Logic Board Replacement: 5 단계, 이미지 3/3
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
  6. LG Dare Logic Board Replacement: 6 단계, 이미지 1/1
    • Disconnect the three ribbon connectors from the motherboard.
  7. LG Dare Logic Board Replacement: 7 단계, 이미지 1/3 LG Dare Logic Board Replacement: 7 단계, 이미지 2/3 LG Dare Logic Board Replacement: 7 단계, 이미지 3/3
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
  8. LG Dare Logic Board Replacement: 8 단계, 이미지 1/1
    • Open the USB port cover.
  9. LG Dare Logic Board Replacement: 9 단계, 이미지 1/3 LG Dare Logic Board Replacement: 9 단계, 이미지 2/3 LG Dare Logic Board Replacement: 9 단계, 이미지 3/3
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
결론
To re-assemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Haoyan Huang
회원 가입일: 01/26/12
139 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-4, Regan Winter 2012 Cal Poly, Team 9-4, Regan Winter 2012 회원
CPSU-REGAN-W12S9G4
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 2,159
