소개
If your LG EnV Touch VX11000 shuts down unexpectedly or the screen is broken or malfunctioning, you may need to replace the motherboard. This guide will show you how to replace the motherboard in an LG EnV Touch VX11000.
필요한 것
Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
다른 3명이 해당 안내서를 완성하였습니다.
