주요 콘텐츠로 건너뛰기
LG EnV Touch VX11000 Screen Assembly Replacement
필요한 것
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Screen Assembly Replacement: 2 단계, 이미지 1/1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Screen Assembly Replacement: 3 단계, 이미지 1/2 LG EnV Touch VX11000 Screen Assembly Replacement: 3 단계, 이미지 2/2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: 4 단계, 이미지 1/2 LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: 4 단계, 이미지 2/2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Screen Assembly Replacement: 5 단계, 이미지 1/1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Screen Assembly Replacement: 6 단계, 이미지 1/2 LG EnV Touch VX11000 Screen Assembly Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 7 단계, 이미지 1/3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 7 단계, 이미지 2/3 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 7 단계, 이미지 3/3
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
  8. LG EnV Touch VX11000 Screen Assembly Replacement: 8 단계, 이미지 1/2 LG EnV Touch VX11000 Screen Assembly Replacement: 8 단계, 이미지 2/2
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
  9. LG EnV Touch VX11000 Screen Assembly Replacement: 9 단계, 이미지 1/2 LG EnV Touch VX11000 Screen Assembly Replacement: 9 단계, 이미지 2/2
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
  10. LG EnV Touch VX11000 Screen Assembly Replacement: 10 단계, 이미지 1/1
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
  11. LG EnV Touch VX11000 Screen Assembly Replacement: 11 단계, 이미지 1/3 LG EnV Touch VX11000 Screen Assembly Replacement: 11 단계, 이미지 2/3 LG EnV Touch VX11000 Screen Assembly Replacement: 11 단계, 이미지 3/3
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
  12. LG EnV Touch VX11000 Screen Assembly Replacement: 12 단계, 이미지 1/2 LG EnV Touch VX11000 Screen Assembly Replacement: 12 단계, 이미지 2/2
    • Unplug the connector from the screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Rachel Smith
회원 가입일: 09/30/13
593 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-2, Forte Fall 2013 Cal Poly, Team 13-2, Forte Fall 2013 회원
CPSU-FORTE-F13S13G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,084
