주요 콘텐츠로 건너뛰기
LG EnV Touch VX11000 Volume and Camera Buttons Replacement
필요한 것
  1. LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: 2 단계, 이미지 1/1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: 3 단계, 이미지 1/2 LG EnV Touch VX11000 Volume and Camera Buttons Replacement: 3 단계, 이미지 2/2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Volume and Camera Buttons: 4 단계, 이미지 1/2 LG EnV Touch VX11000 Volume and Camera Buttons Replacement, Volume and Camera Buttons: 4 단계, 이미지 2/2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: 5 단계, 이미지 1/1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Volume and Camera Buttons Replacement: 6 단계, 이미지 1/2 LG EnV Touch VX11000 Volume and Camera Buttons Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
결론
Rachel Smith
회원 가입일: 09/30/13
593 평판
안내서 5개 작성하였습니다
Cal Poly, Team 13-2, Forte Fall 2013 Cal Poly, Team 13-2, Forte Fall 2013 회원
CPSU-FORTE-F13S13G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 273
