주요 콘텐츠로 건너뛰기
LG EnV VX9900 Circuit Board and Full Key Board Replacement
필요한 것
  1. LG EnV VX9900 Circuit Board and Full Key Board Replacement, Battery: 1 단계, 이미지 1/1
    • Place the phone so the screen side is facing down.
    • Locate the latch at the end of the phone, opposite of the camera.
  2. LG EnV VX9900 Circuit Board and Full Key Board Replacement: 2 단계, 이미지 1/1
    • Push/pull the latch away from the camera, causing the battery to pop out.
  3. LG EnV VX9900 Circuit Board and Full Key Board Replacement: 3 단계, 이미지 1/1
    • Remove the battery.
  4. LG EnV VX9900 Circuit Board and Full Key Board Replacement, Circuit Board and Full Key Board: 4 단계, 이미지 1/2 LG EnV VX9900 Circuit Board and Full Key Board Replacement, Circuit Board and Full Key Board: 4 단계, 이미지 2/2
    • Remove the 5 screw covers on the back of the phone using a Push Pin.
  5. LG EnV VX9900 Circuit Board and Full Key Board Replacement: 5 단계, 이미지 1/1
    • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
    • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
  6. LG EnV VX9900 Circuit Board and Full Key Board Replacement: 6 단계, 이미지 1/2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: 6 단계, 이미지 2/2
    • Open the phone.
  7. LG EnV VX9900 Circuit Board and Full Key Board Replacement: 7 단계, 이미지 1/2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: 7 단계, 이미지 2/2
    • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
    • Prying open the part just to the left of the right hinge can be difficult.
    • Remove the back colored casing and set it to the side.
  8. LG EnV VX9900 Circuit Board and Full Key Board Replacement: 8 단계, 이미지 1/2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: 8 단계, 이미지 2/2
    • Gently pry and detach the connection located near the hinge with fingers.
  9. LG EnV VX9900 Circuit Board and Full Key Board Replacement: 9 단계, 이미지 1/2 LG EnV VX9900 Circuit Board and Full Key Board Replacement: 9 단계, 이미지 2/2
    • The circuit board and the key board will be attached, as shown in the second picture.
    • Lift them both out from the rest of the phone.
    • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
결론
Stephanie Villavicencio
회원 가입일: 04/05/12
28 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-15, Forte Spring 2012 Cal Poly, Team 15-15, Forte Spring 2012 회원
CPSU-FORTE-S12S15G15
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,269
