이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the device over so the backside is facing up.
Use your fingers or an opening tool to remove the back cover in order to expose the battery.
Use your fingers or a spudger to remove the battery. Lift it from the side opposite of the camera.
Use a Phillips #0 screwdriver to remove six screws around the perimeter of the phone.
Place the opening tool in the seam of the device and pry around the perimeter to separate the top case from the bottom case.
Place the opening tool on the top on the device between the phone casing and motherboard.
Separate the screen and the motherboard.
다른 한 분이 해당 안내서를 완성하였습니다.
