주요 콘텐츠로 건너뛰기
LG Encore GT550 Camera Replacement
필요한 것
  1. LG Encore GT550 Camera Replacement, Camera: 1 단계, 이미지 1/2 LG Encore GT550 Camera Replacement, Camera: 1 단계, 이미지 2/2
    • Remove the back cover of the phone using your fingers.
  2. LG Encore GT550 Camera Replacement: 2 단계, 이미지 1/1
    • Use your fingers to remove the battery.
  3. LG Encore GT550 Camera Replacement: 3 단계, 이미지 1/1
    • Remove the six screws around the outside of the phone using a Phillips #0 screwdriver.
  4. LG Encore GT550 Camera Replacement: 4 단계, 이미지 1/2 LG Encore GT550 Camera Replacement: 4 단계, 이미지 2/2
    • Hook the iFixit opening tool onto the side of the front panel.
    • Pry away from the phone with the opening tool to remove the front panel.
  5. LG Encore GT550 Camera Replacement: 5 단계, 이미지 1/2 LG Encore GT550 Camera Replacement: 5 단계, 이미지 2/2
    • Insert the small end of the opening tool between the motherboard and the side of the phone.
    • Use leverage to remove the motherboard.
  6. LG Encore GT550 Camera Replacement: 6 단계, 이미지 1/1
    • Using the opening tool, detach the camera from the motherboard.
결론
Lindsey Harding
회원 가입일: 11/04/13
501 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-4, Shastany Fall 2013 UMass Dartmouth, Team 1-4, Shastany Fall 2013 회원
UMASSD-SHASTANY-F13S1G4
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 200
