주요 콘텐츠로 건너뛰기
LG Escape (p870) Rear Camera Replacement
필요한 것
  1. LG Escape (p870) Rear Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG Escape (p870) Rear Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) Rear Camera Replacement: 2 단계, 이미지 2개 중 1개 LG Escape (p870) Rear Camera Replacement: 2 단계, 이미지 2개 중 2개
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) Rear Camera Replacement, Loudspeaker Assembly: 3 단계, 이미지 1개 중 1개
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) Rear Camera Replacement: 4 단계, 이미지 2개 중 1개 LG Escape (p870) Rear Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
  5. LG Escape (p870) Rear Camera Replacement, Rear Camera: 5 단계, 이미지 1개 중 1개
    • Remove the remaining 6 screws securing the plastic frame to the back housing
  6. LG Escape (p870) Rear Camera Replacement: 6 단계, 이미지 3개 중 1개 LG Escape (p870) Rear Camera Replacement: 6 단계, 이미지 3개 중 2개 LG Escape (p870) Rear Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
    • Continue working your way around the phone, prying carefully with your prying tool
    • When you work the frame free, set it aside
  7. LG Escape (p870) Rear Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Use a plastic spudger or safe-open pry tool to release the camera's flex cable from its connector
    • Remove the camera from the housing and set it aside
결론
작성자
2다른 기여자 명과 함께
Brad
회원 가입일: 08/12/12
1,956 평판
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 534
