주요 콘텐츠로 건너뛰기
LG Escape (p870) Touch screen/digitizer Replacement
필요한 것
  1. LG Escape (p870) Touch screen/digitizer Replacement, Battery: 1 단계, 이미지 1/2 LG Escape (p870) Touch screen/digitizer Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) Touch screen/digitizer Replacement: 2 단계, 이미지 1/2 LG Escape (p870) Touch screen/digitizer Replacement: 2 단계, 이미지 2/2
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) Touch screen/digitizer Replacement, Loudspeaker Assembly: 3 단계, 이미지 1/1
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) Touch screen/digitizer Replacement: 4 단계, 이미지 1/2 LG Escape (p870) Touch screen/digitizer Replacement: 4 단계, 이미지 2/2
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
  5. LG Escape (p870) Touch screen/digitizer Replacement, Touch screen/digitizer: 5 단계, 이미지 1/1
    • Remove the remaining 6 screws securing the plastic frame to the back housing
  6. LG Escape (p870) Touch screen/digitizer Replacement: 6 단계, 이미지 1/3 LG Escape (p870) Touch screen/digitizer Replacement: 6 단계, 이미지 2/3 LG Escape (p870) Touch screen/digitizer Replacement: 6 단계, 이미지 3/3
    • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
    • Continue working your way around the phone, prying carefully with your prying tool
    • When you work the frame free, set it aside
  7. LG Escape (p870) Touch screen/digitizer Replacement: 7 단계, 이미지 1/1
    • Wifi and cell service antennas
    • LCD connector
    • Back camera connector
    • Front camera connector
    • Touch screen/ digitizer connector
    • Charger port connector
    • Headphone jack connector
  8. LG Escape (p870) Touch screen/digitizer Replacement: 8 단계, 이미지 1/3 LG Escape (p870) Touch screen/digitizer Replacement: 8 단계, 이미지 2/3 LG Escape (p870) Touch screen/digitizer Replacement: 8 단계, 이미지 3/3
    • With a spudger or safe open pry tool, carefully detach the LCD flex connector
    • Release the two antennae from their connectors
    • Release the back camera's flex from its connector
  9. LG Escape (p870) Touch screen/digitizer Replacement: 9 단계, 이미지 1/2 LG Escape (p870) Touch screen/digitizer Replacement: 9 단계, 이미지 2/2
    • Release the charging port flex from its connector
    • Release the front camera's flex from its connector
    • Release the touch screen/digitizer's flex cable from its connector
  10. LG Escape (p870) Touch screen/digitizer Replacement: 10 단계, 이미지 1/1
    • Release the headphone jack's flex cable from its connector
  11. LG Escape (p870) Touch screen/digitizer Replacement: 11 단계, 이미지 1/2 LG Escape (p870) Touch screen/digitizer Replacement: 11 단계, 이미지 2/2
    • With a pair of tweezers, VERY carefully pull the volume button flex out of the rear housing
    • Repeat the process with the power button flex cable
    • The power button and volume button flex cables will tear very easily, so be cautious
  12. LG Escape (p870) Touch screen/digitizer Replacement: 12 단계, 이미지 1/2 LG Escape (p870) Touch screen/digitizer Replacement: 12 단계, 이미지 2/2
    • Lift the motherboard away from the housing, taking extra care not to snag any of the antennae or flex cables
    • Set the motherboard aside
  13. LG Escape (p870) Touch screen/digitizer Replacement: 13 단계, 이미지 1/2 LG Escape (p870) Touch screen/digitizer Replacement: 13 단계, 이미지 2/2
    • Insert a small flathead screwdriver or black plastic spudger between the front silver bezel and the black plastic mid-frame
    • Gently pry on the bezel to release the clips adhering the screen to the mid-frame
    • Work your way around the phone, still using the small flathead or spudger, until the screen is fully separated
    • Remove the screen, taking care not to tear the flex cable that is still threaded through the housing.
    • After carefully threading the digitizer and outer housing/bezel from the middle bracket you'll notice the digitizer is held on by a band of very strong adhesive - this will be destroyed when you take off the old digitizer. When you replace your digitizer you can use double-sided tape or epoxy to hold the new digitizer on the bezel.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Brad
회원 가입일: 08/12/12
1,908 평판
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 13,983
