주요 콘텐츠로 건너뛰기
LG Flare Microphone Replacement
필요한 것
  1. LG Flare Microphone Replacement, Microphone: 1 단계, 이미지 1/2 LG Flare Microphone Replacement, Microphone: 1 단계, 이미지 2/2
    • Remove the back cover by pressing on the top middle raised lines of the back cover and sliding the cover off.
  2. LG Flare Microphone Replacement: 2 단계, 이미지 1/1
    • Remove the battery by popping the top out and removing the battery.
  3. LG Flare Microphone Replacement: 3 단계, 이미지 1/1
    • Use appropriately sized Philips-head screwdriver to remove the six small screws on the back of the phone under the battery.
  4. LG Flare Microphone Replacement: 4 단계, 이미지 1/1
    • Use an opening tool to pop the back panel apart around the edges, and then pry the whole piece off.
  5. LG Flare Microphone Replacement: 5 단계, 이미지 1/1
    • Use an opening tool to separate the tabs on the green circuit board from the front body of the phone.
  6. LG Flare Microphone Replacement: 6 단계, 이미지 1/1
    • Use an opening tool to pop the orange connecting strip off of the circuit board.
  7. LG Flare Microphone Replacement: 7 단계, 이미지 1/1
    • Un-clip the 2 metal clips on one side of the circuit board.
  8. LG Flare Microphone Replacement: 8 단계, 이미지 1/2 LG Flare Microphone Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers and wedge, remove silver piece from green circuit board.
  9. LG Flare Microphone Replacement: 9 단계, 이미지 1/1
    • Remove the microphone (rip soldering).
  10. LG Flare Microphone Replacement: 10 단계, 이미지 1/1
    • Solder new microphone in place OR buy replacement circuit board from www.ifixit.com and replace.
결론
Kelsey Hanna
회원 가입일: 09/29/15
1 평판
안내서 1개 작성함
Ohio State, Team 1-3, Garvin Fall 2015 Ohio State, Team 1-3, Garvin Fall 2015 회원
OSU-GARVIN-F15S1G3
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 185
