소개
Hello, in this guide I’ll show you how to replace the capacitors on this monitor and possibly make it working again.
필요한 것
Use a spudger to remove the plastic basel around the display and remove any screws that you see on the back.
Carefully lift up the display assembly and set it aside.
After you flip the metal bracket, it should look something like this.
Identify the faulty capacitors, remove them and solder new ones.
In my case, those marked in blue were busted and prevented the monitor from working.
For good measure I replaced all of them with brand new ones. It is a good idea that you do too.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 2개
This repair guide helped me fix my LG Flatron W2242T 22" computer monitor that powered off but would not power back on.
After making the repair, replacing bulging capacitors C203, C204, C205, and C212 with replacements of the same value, the monitor powered back on and works again!
Hello,
I am very glad to hear that my guide helped you!
