주요 콘텐츠로 건너뛰기
LG Front Load Washing Machine Air Dome Replacement
필요한 것
  1. LG Front Load Washing Machine Air Dome Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Air Dome Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Air Dome Replacement, Unfasten the rear panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the rear panel.
  3. LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Air Dome Replacement, Remove the rear panel: 3 단계, 이미지 3개 중 3개
    • Unclip the rear panel from the chassis.
  4. LG Front Load Washing Machine Air Dome Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the rear panel.
  5. LG Front Load Washing Machine Air Dome Replacement, Disconnect the air dome: 5 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Air Dome Replacement, Disconnect the air dome: 5 단계, 이미지 2개 중 2개
    • Pull the hose straight off the air dome hose to disconnect it.
  6. LG Front Load Washing Machine Air Dome Replacement, Unfasten the air dome: 6 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the air dome.
  7. LG Front Load Washing Machine Air Dome Replacement: 7 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Air Dome Replacement: 7 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Air Dome Replacement: 7 단계, 이미지 3개 중 3개
    • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
  8. LG Front Load Washing Machine Air Dome Replacement, Remove the air dome: 8 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Air Dome Replacement, Remove the air dome: 8 단계, 이미지 2개 중 2개
    • Pull the air dome straight off its hose to remove it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,506 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 67
전체 시간: 1,525
