주요 콘텐츠로 건너뛰기
LG Front Load Washing Machine Detergent Bellows Replacement
필요한 것
  1. LG Front Load Washing Machine Detergent Bellows Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Detergent Bellows Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Detergent Bellows Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Detergent Bellows Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Detergent Bellows Replacement: 4 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the control panel: 5 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the control panel: 5 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the control panel: 5 단계, 이미지 3개 중 3개
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG Front Load Washing Machine Detergent Bellows Replacement, Unclip the control panel cable: 6 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement, Unclip the control panel cable: 6 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Detergent Bellows Replacement, Unclip the control panel cable: 6 단계, 이미지 3개 중 3개
    • Unclip any connections the control panel cable has to the chassis or other components.
  7. LG Front Load Washing Machine Detergent Bellows Replacement, Detergent dispenser hose information: 7 단계, 이미지 1개 중 1개
    • To prevent confusion, label each detergent hose and its corresponding dispenser connection.
    • You can use masking tape or mark the components themselves.
  8. LG Front Load Washing Machine Detergent Bellows Replacement: 8 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement: 8 단계, 이미지 2개 중 2개
    • Use slip joint pliers to pinch the detergent dispenser hose clamp and pull it away from the assembly.
  9. LG Front Load Washing Machine Detergent Bellows Replacement: 9 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement: 9 단계, 이미지 2개 중 2개
    • Use slip joint pliers to gently rotate the detergent dispenser hose back and forth around its connection and loosen it.
  10. LG Front Load Washing Machine Detergent Bellows Replacement: 10 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement: 10 단계, 이미지 2개 중 2개
    • Pull the detergent dispenser hose straight off its connection on the assembly.
    • Repeat the loosening and removal procedure for each hose.
  11. LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the dispenser: 11 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the dispenser: 11 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the dispenser: 11 단계, 이미지 3개 중 3개
    • Loosen any fasteners securing the bellows to the detergent dispenser.
    • Pull the bellows straight off its connection on the dispenser to disconnect it.
  12. LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the bellows: 12 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the bellows: 12 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Detergent Bellows Replacement, Disconnect the bellows: 12 단계, 이미지 3개 중 3개
    • Loosen the fastener securing the bellows to the drum.
    • Pull the bellows straight up from the drum to disconnect it.
  13. LG Front Load Washing Machine Detergent Bellows Replacement, Remove the bellows: 13 단계, 이미지 1개 중 1개
    • You're now left with the bellows.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,500 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,648개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 64
전체 시간: 766
