주요 콘텐츠로 건너뛰기
LG Front Load Washing Machine Drain Filter Replacement
  1. LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: 1 단계, 이미지 1/2 LG Front Load Washing Machine Drain Filter Replacement, Unclip the filter door: 1 단계, 이미지 2/2
    • Unclip the filter door from its slot in the chassis and let it rest on the ground.
  2. LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: 2 단계, 이미지 1/3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: 2 단계, 이미지 2/3 LG Front Load Washing Machine Drain Filter Replacement, Drain the drain filter hose: 2 단계, 이미지 3/3
    • Place a bowl next to the device.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  3. LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: 3 단계, 이미지 1/3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: 3 단계, 이미지 2/3 LG Front Load Washing Machine Drain Filter Replacement, Remove the drain filter: 3 단계, 이미지 3/3
    • Twist the drain filter counterclockwise until it's fully disconnected from the chassis.
    • Remove the drain filter.
결론
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
회원 가입일: 06/30/22
30,088 평판
안내서 213개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,430개 작성하였습니다
댓글 한 개
I need to replace the clip door it fell off when we moved.
Maria Medina - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 23
30일 전: 118
전체 시간: 1,067
