주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG Front Load Washing Machine Inlet Valve Assembly Replacement
필요한 것
  1. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 4 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 5 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 5 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Inlet valve information: 5 단계, 이미지 3개 중 3개
    • To prevent confusion, label each valve and its corresponding hose.
    • You can use masking tape or mark the components themselves.
    • Repeat the labelling procedure for each valve and its corresponding connector.
  6. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 6 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 6 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Disconnect the inlet valve: 6 단계, 이미지 3개 중 3개
    • Disconnect the connectors from the inlet valve.
    • Always grip cables by their connectors and not the wires themselves.
  7. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Place a dry rag under the inlet valve to soak up any lingering water.
  8. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 8 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 8 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Use slip joint pliers to pinch the inlet valve hose clamp and pull it away from the inlet valve assembly.
  9. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 9 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • Use slip joint pliers to rotate the inlet valve hose back and forth around its connection and loosen it.
  10. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 10 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement: 10 단계, 이미지 2개 중 2개
    • Pull the inlet valve hose straight off its connection on the inlet valve assembly.
  11. LG Front Load Washing Machine Inlet Valve Assembly Replacement: 11 단계, 이미지 1개 중 1개
    • Repeat the previous three steps for each remaining hose attached to the inlet valve assembly.
  12. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 12 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 12 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the filters: 12 단계, 이미지 3개 중 3개
    • If your replacement part comes with filters pre-installed, skip this step.
    • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
    • Remove the filters.
  13. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Unfasten the inlet valve assembly: 13 단계, 이미지 1개 중 1개
    • Remove the screws securing the inlet valve assembly.
  14. LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 14 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 14 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Inlet Valve Assembly Replacement, Remove the inlet valve assembly: 14 단계, 이미지 3개 중 3개
    • Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,580 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,891개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 75
지난 30일: 238
전체 시간: 5,154
