주요 콘텐츠로 건너뛰기
LG Front Load Washing Machine Inlet Valve Filters Replacement
필요한 것
  1. LG Front Load Washing Machine Inlet Valve Filters Replacement, Safety Precautions: 1 단계, 이미지 1/2 LG Front Load Washing Machine Inlet Valve Filters Replacement, Safety Precautions: 1 단계, 이미지 2/2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Inlet Valve Filters Replacement, Remove the filters: 2 단계, 이미지 1/3 LG Front Load Washing Machine Inlet Valve Filters Replacement, Remove the filters: 2 단계, 이미지 2/3 LG Front Load Washing Machine Inlet Valve Filters Replacement, Remove the filters: 2 단계, 이미지 3/3
    • Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
    • Remove the filters.
결론
Repair didn’t go as planned? Ask our Answers community for help.
Bill Gilbert
회원 가입일: 06/30/22
30,088 평판
안내서 213개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,420개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 28
전체 시간: 423
