주요 콘텐츠로 건너뛰기
LG Front Load Washing Machine Pump Hose Replacement
필요한 것
  1. LG Front Load Washing Machine Pump Hose Replacement, Safety Precautions: 1 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Safety Precautions: 1 단계, 이미지 2/2
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: 2 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: 2 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: 2 단계, 이미지 3/3
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Pump Hose Replacement, Remove the top panel: 3 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Remove the top panel: 3 단계, 이미지 2/2
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Pump Hose Replacement: 4 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement: 4 단계, 이미지 2/2
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Pump Hose Replacement, Remove the detergent drawer: 5 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Remove the detergent drawer: 5 단계, 이미지 2/2
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. LG Front Load Washing Machine Pump Hose Replacement: 6 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement: 6 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement: 6 단계, 이미지 3/3
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: 7 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: 7 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: 7 단계, 이미지 3/3
    • Disconnect the connectors attached to the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the control panel: 8 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the control panel: 8 단계, 이미지 2/2
    • Remove the screw(s) securing the control panel to the top edge of the chassis.
  9. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the detergent dispenser: 9 단계, 이미지 1/1
    • Remove the screw(s) securing the detergent dispenser.
  10. LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: 10 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: 10 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: 10 단계, 이미지 3/3
    • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
  11. LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: 11 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: 11 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: 11 단계, 이미지 3/3
    • Remove the control panel, making sure to thread any cables through the chassis.
  12. LG Front Load Washing Machine Pump Hose Replacement, Open the door: 12 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Open the door: 12 단계, 이미지 2/2
    • Open the front door completely.
  13. LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: 13 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: 13 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: 13 단계, 이미지 3/3
    • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
    • Pull the ring away from the chassis to separate it from the boot.
  14. LG Front Load Washing Machine Pump Hose Replacement: 14 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement: 14 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement: 14 단계, 이미지 3/3
    • Use your hand to completely pull the ring off the boot.
    • During reassembly, perform the following:
    • Insert one end of the ring into its groove along the boot's perimeter.
    • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
    • Be sure the spring is centered at the bottom of the boot when you reinstall it.
    • This procedure will take significant force.
  15. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: 15 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: 15 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: 15 단계, 이미지 3/3
    • Use your fingers to pull the boot off its lip on the front panel.
  16. LG Front Load Washing Machine Pump Hose Replacement: 16 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement: 16 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement: 16 단계, 이미지 3/3
    • Slide your fingers around the lip of the boot until it's completely separated from the panel.
  17. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: 17 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: 17 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: 17 단계, 이미지 3/3
    • Open the filter panel at the bottom of the front panel.
    • Unclip the filter panel.
  18. LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: 18 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: 18 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: 18 단계, 이미지 3/3
    • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
    • Place a bowl next to the machine.
    • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
    • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
    • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
  19. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the filter trim: 19 단계, 이미지 1/1
    • Remove the screw(s) securing the filter trim.
  20. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter trim: 20 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Remove the filter trim: 20 단계, 이미지 2/2
    • Pull the filter trim straight off the front panel to remove it.
  21. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the lower front panel: 21 단계, 이미지 1/1
    • Remove the screw(s) securing the lower front panel.
  22. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the door latch: 22 단계, 이미지 1/1
    • Remove the screw(s) securing the door latch.
  23. LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: 23 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: 23 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: 23 단계, 이미지 3/3
    • Pull the door latch through its slot in the chassis and let it hang on its wire.
  24. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: 24 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: 24 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: 24 단계, 이미지 3/3
    • Hold the front panel against the chassis while performing this step to prevent it from falling.
    • Remove the screw(s) securing the front panel.
  25. LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: 25 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: 25 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: 25 단계, 이미지 3/3
    • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
    • Pull the front panel away from the chassis to completely separate the front panel.
  26. LG Front Load Washing Machine Pump Hose Replacement: 26 단계, 이미지 1/1
    • Remove the front panel.
  27. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: 27 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: 27 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: 27 단계, 이미지 3/3
    • Use slip joint pliers to pinch the tub to pump hose clamp and pull it away from the assembly.
    • Pull the hose straight off the assembly to disconnect it.
  28. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: 28 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: 28 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: 28 단계, 이미지 3/3
    • Remove the screw(s) securing the rear panel.
  29. LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: 29 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: 29 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: 29 단계, 이미지 3/3
    • Unclip the rear panel from the chassis.
  30. LG Front Load Washing Machine Pump Hose Replacement: 30 단계, 이미지 1/1
    • Remove the rear panel.
  31. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the air dome: 31 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the air dome: 31 단계, 이미지 2/2
    • Pull the hose straight off the air dome hose to disconnect it.
  32. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the air dome: 32 단계, 이미지 1/1
    • Remove the screw(s) securing the air dome.
  33. LG Front Load Washing Machine Pump Hose Replacement: 33 단계, 이미지 1/3 LG Front Load Washing Machine Pump Hose Replacement: 33 단계, 이미지 2/3 LG Front Load Washing Machine Pump Hose Replacement: 33 단계, 이미지 3/3
    • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
  34. LG Front Load Washing Machine Pump Hose Replacement, Remove the air dome: 34 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Remove the air dome: 34 단계, 이미지 2/2
    • Pull the air dome straight off its hose to remove it.
  35. LG Front Load Washing Machine Pump Hose Replacement, Loosen the pump hose: 35 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Loosen the pump hose: 35 단계, 이미지 2/2
    • Use a Phillips driver to loosen the pump hose from the drum enough to disconnect it.
  36. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the pump hose: 36 단계, 이미지 1/2 LG Front Load Washing Machine Pump Hose Replacement, Disconnect the pump hose: 36 단계, 이미지 2/2
    • Pull the pump hose straight off the drum to disconnect it.
  37. LG Front Load Washing Machine Pump Hose Replacement, Remove the pump hose: 37 단계, 이미지 1/1
    • Remove the pump hose.
    • During reassembly, use liquid laundry detergent to lubricate the hose around its tub connection.
결론
Bill Gilbert
회원 가입일: 06/30/22
30,088 평판
안내서 213개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,420개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 27
30일 전: 82
전체 시간: 702
