주요 콘텐츠로 건너뛰기
LG Front Load Washing Machine Rotor Position Sensor Replacement
필요한 것
  1. LG Front Load Washing Machine Rotor Position Sensor Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Rotor Position Sensor Replacement: 4 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the rotor: 5 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the rotor: 5 단계, 이미지 2개 중 2개
    • Use an impact driver to remove the 17 mm nut securing the rotor.
    • Alternatively, you can use a wrench and a hammer to loosen the nut.
    • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
  6. LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor: 6 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor: 6 단계, 이미지 2개 중 2개
    • The rotor is magnetically attracted to the stator.
    • Pull the rotor straight off the stator and drive shaft splines to remove it.
    • Wiggle the rotor as you pull to help disconnect it.
    • This may require significant force.
    • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
  7. LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the motor harness clamps: 7 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the motor harness clamps.
  8. LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the stator: 8 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Unfasten the stator: 8 단계, 이미지 2개 중 2개
    • Hold the stator up as you unfasten the last few bolts, as it can fall over unexpectedly.
    • Remove the bolt(s) securing the stator.
    • During reassembly, refasten the screws in a "star" pattern.
  9. LG Front Load Washing Machine Rotor Position Sensor Replacement, Reposition the stator: 9 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Reposition the stator: 9 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Reposition the stator: 9 단계, 이미지 3개 중 3개
    • Don't pull the stator too far away from the device, as it's still connected by wires.
    • Pull the stator off of the drum and flip it so its rear is facing upward.
    • Note the position of the stator before continuing, as you will need it face the proper direction during reassembly.
  10. LG Front Load Washing Machine Rotor Position Sensor Replacement, Disconnect the rotor position sensor: 10 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Disconnect the rotor position sensor: 10 단계, 이미지 2개 중 2개
    • Pull the rotor position sensor connector straight out of its socket to disconnect it.
  11. LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor position sensor: 11 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor position sensor: 11 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Rotor Position Sensor Replacement, Remove the rotor position sensor: 11 단계, 이미지 3개 중 3개
    • Use your fingers to unclip the rotor position sensor from the stator.
    • Pull the sensor away from the stator to completely unclip it.
    • Remove the rotor position sensor.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,555 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,788개를 작성함
2가이드 댓글
Thank you and your video, I was able to replace my motor rotor position sensor easily and avoided throwing away a good washer (8 years old), $700 for a new one, not to mention the damage to the environment. Need sockets, 17mm and 10mm. I recommend to test the resistance of the part(see Felix Techno Aid video), before installation to make sure the part is good. I want to acknowledge other good videos on this subject, Felix Techno Aid, Appliance Parts Pros.com, Repair Clinic.com and IFixit by Bill Gilbert. Thank you all for your videos.
Prasad Gogineni - 답글
I did not have to disconnect the water hoses or remove the top cover as shown in this video. I had lot of room in the laundry to move it around. This video is missing the step to show removal of the back panel to get access to the motor (before step 5).
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 29
지난 30일: 113
전체 시간: 3,599
