소개
This will give instructions on how to remove the two different speakers inside the tablet and how to remove them.
필요한 것
To remove the back panel of the device, start by attempting to fit the plastic opening tool in the crease between the screen and the back panel of the tablet.
Try opening picks if the case is not flexing enough, or if it is already cracked to prevent further damage.
You can use your hands to push against the corners of the device to attempt to make the gap larger for your plastic opening tool to fit in.
If you are replacing your screen because it is damaged, it may be useful to pick away at some of the glass to expose the clips in the edges of the plastic.
Insert the corners of your plastic opening tool into the slots that are on the very outside edge of your device to start disconnecting the panel.
Remove the five 2 mm Phillips #000 screws securing the motherboard.
The silver EMI shield may come off during this step. Just set it aside until reassembly.
Trace the red and black wire down the side of the device while sliding it out from under the small black clips as you work your way towards the end of the cable.
While holding the orange ribbon cable in place with your finger, grab the wires and pull upwards to disconnect the speaker from the device.
다른 한 분이 해당 안내서를 완성하였습니다.
