주요 콘텐츠로 건너뛰기
LG G Pad 7.0 Battery Replacement
필요한 것
  1. LG G Pad 7.0 Battery Replacement, LG G-Pad 7.0: 1 단계, 이미지 1/1
    • Here it is - LG G-Pad 7.0. Let's dive right in!
  2. LG G Pad 7.0 Battery Replacement, Jumping right into action: 2 단계, 이미지 1/2 LG G Pad 7.0 Battery Replacement, Jumping right into action: 2 단계, 이미지 2/2
    • First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
  3. LG G Pad 7.0 Battery Replacement, First Glimpse: 3 단계, 이미지 1/1
    • Vuala! We're in! Carefully slide the screen assembly away from the back cover.
  4. LG G Pad 7.0 Battery Replacement, A Look on the Inside: 4 단계, 이미지 1/1
    • Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
  5. LG G Pad 7.0 Battery Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Grab your * Tweezers, the best tweezers you can get!
  6. LG G Pad 7.0 Battery Replacement, Charging Port Flex: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully pry up the charging port connection from the bottom left with your Tweezers.
  7. LG G Pad 7.0 Battery Replacement, Battery Connection: 7 단계, 이미지 1/1
    • Carefully lift the battery connector.
  8. LG G Pad 7.0 Battery Replacement, Removing the Battery: 8 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iSesamo Opening Tool
    $9.99
    구매
  9. LG G Pad 7.0 Battery Replacement, Disposal of old Battery: 9 단계, 이미지 1/1
    • After removing the faulty/dead battery, make sure you properly dispose it.
  10. LG G Pad 7.0 Battery Replacement, Don't Forget!: 10 단계, 이미지 1/2 LG G Pad 7.0 Battery Replacement, Don't Forget!: 10 단계, 이미지 2/2
    • After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • There you go! A quick battery replacement on your LG G-Pad.
결론
다른 2명이 해당 안내서를 완성하였습니다.
GadgetERService
회원 가입일: 11/22/13
1,650 평판
안내서 2개 작성하였습니다
Minnesota Repair Techs Minnesota Repair Techs 회원
Community
3 회원들
안내서 2개 작성하였습니다
댓글 2개
Big thanks to the Author for this, I used it on my v410, worked perfect !
Max Haxster - 답글
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
Mario Escobar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 16
전체 시간: 2,694
