주요 콘텐츠로 건너뛰기
소개
This guide will show you step by step how to access the internals of a LG G Pad 7.0(LG-V410) and replace the battery.
  1. Here it is - LG G-Pad 7.0. Let's dive right in!
    • Here it is - LG G-Pad 7.0. Let's dive right in!
  2. First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard.. First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
    • First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
  3. Vuala!  We're in! Carefully slide the screen assembly away from the back cover.
    • Vuala! We're in! Carefully slide the screen assembly away from the back cover.
  4. Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
    • Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
    • Grab your * Tweezers, the best tweezers you can get!
    • Carefully pry up the charging port connection from the bottom left with your Tweezers.
  5. Carefully lift the battery connector.
    • Carefully lift the battery connector.
  6. After removing the faulty/dead battery, make sure you properly dispose it.
    • After removing the faulty/dead battery, make sure you properly dispose it.
  7. After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place. After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
    • There you go! A quick battery replacement on your LG G-Pad.
결론
다른 2명이 해당 안내서를 완성하였습니다.
GadgetERService
회원 가입일: 2013년 11월 22일
1,626 평판
안내서 2개 작성하였습니다
Minnesota Repair Techs Minnesota Repair Techs 회원
Community
3 회원들
안내서 2개 작성하였습니다
댓글 2개
Big thanks to the Author for this, I used it on my v410, worked perfect !
Max Haxster - 답글
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
Mario Escobar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,385
