이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will show you step by step how to access the internals of a LG G Pad 7.0(LG-V410) and replace the battery.
필요한 것
First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
Vuala! We're in! Carefully slide the screen assembly away from the back cover.
Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
이 단계에 사용된 도구:iSesamo Opening Tool$9.99
Grab your iSesamo Opening Tool and break the adhesive around the edges of the battery.
After removing the faulty/dead battery, make sure you properly dispose it.
After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
Big thanks to the Author for this, I used it on my v410, worked perfect !
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
