이 단계는 번역되지 않았습니다. 번역을 도와주십시오
First things first, use the handy pick iFixit sells on their online store. Carefully pry the frame apart in between the screen assembly an back cover. Be extremely careful, you don't want to damage the motherboard..
Vuala! We're in! Carefully slide the screen assembly away from the back cover.
Here's the inside of the tablet. Pretty straight forward, nothing to spectacular.
Carefully pry up the charging port connection from the bottom left with your Tweezers.
Grab your iSesamo Opening Tool and break the adhesive around the edges of the battery.
After removing the faulty/dead battery, make sure you properly dispose it.
After reconnecting the new battery and charging flex cable, make sure you put the headphone jack back into place.
다른 2명이 해당 안내서를 완성하였습니다.
2 Comments
Big thanks to the Author for this, I used it on my v410, worked perfect !
My G pad 7.0 wont turn on. Do I have to do some kind or re-boot or restart it? Cause one time when I changed mi iPhone 5c's battery I had to restart it the phone.
