주요 콘텐츠로 건너뛰기
LG G Pad 7.0 Battery Replacement
필요한 것
  1. LG G Pad 7.0 Battery Replacement, Front Panel: 1 단계, 이미지 1/2 LG G Pad 7.0 Battery Replacement, Front Panel: 1 단계, 이미지 2/2
    • The screen assembly is secured to the plastic backing with clips. Insert the spudger between the screen and plastic.
    • Work your way around the device, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Attempt to lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Battery Replacement, Battery Connector: 2 단계, 이미지 1/3 LG G Pad 7.0 Battery Replacement, Battery Connector: 2 단계, 이미지 2/3 LG G Pad 7.0 Battery Replacement, Battery Connector: 2 단계, 이미지 3/3
    • Remove the battery connector marked in orange, by prying it upwards.You may need some force to do this, be careful not to damage anything.
    • Remove the other connector marked in red by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
  3. LG G Pad 7.0 Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Gently pry the battery up making sure not to bend it or snag any cables.
    • The battery is secured by two pieces of double sided tape on the left and right edges under the battery.
결론
다른 18명이 해당 안내서를 완성하였습니다.
echow2001
회원 가입일: 09/05/15
2,117 평판
안내서 4개 작성하였습니다
LGBTQ Technicians LGBTQ Technicians 회원
Community
14 회원들
안내서 23개 작성하였습니다
댓글 한 개
Thank you for this guide. The iFixit tool worked much better than the one that came with the replacement battery. I needed a magnifying glass to verify I lined up the ribbon cable connector but other than that it went smoothly.
Juan Campos - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 36
전체 시간: 17,322
