주요 콘텐츠로 건너뛰기
LG G Pad 7.0 LTE Speaker Replacement
필요한 것
  1. LG G Pad 7.0 LTE Speaker Replacement, Removing the Back Cover: 1 단계, 이미지 1/1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Speaker Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Remove (1) Silver 3mm PH0 screw from the speaker (red marker).
  4. LG G Pad 7.0 LTE Speaker Replacement: 4 단계, 이미지 1/1
    • Remove speaker from device.
결론
Fadi Bitar
회원 가입일: 09/26/16
880 평판
안내서 6개 작성하였습니다
USF Tampa, Team 14-6, Eyestone Fall 2016 USF Tampa, Team 14-6, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G6
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 414
