주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide will cover how to replace the motherboard on the LG G Pad 7.0
부품
지정된 부품이 없습니다.
  1. The screen assembly is secured to the plastic backing with clips.  Insert the plastic opening tool between the screen and plastic. Work your way around the device, freeing it from the connecting clips.
    • The screen assembly is secured to the plastic backing with clips. Insert the plastic opening tool between the screen and plastic.
    • Work your way around the device, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile. You will have to remove the metallic tape near the bottom of the tablet to  disconnect  the display cable. Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
    • Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
    • You will have to remove the metallic tape near the bottom of the tablet to disconnect the display cable.
    • Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the 7 screws marked in red that are securing the logic board to the case. Be sure that all the connectors marked in orange are removed before pulling out the mother board.
    • Remove the 7 screws marked in red that are securing the logic board to the case.
    • Be sure that all the connectors marked in orange are removed before pulling out the mother board.
    • Very carefully remove the logic board after the screws have been removed
  5. Remove the two screw marked in red. Using the tweezers , pull out the metal bracket that holds the charging port in place. Pull out the ribbon connector in orange.
    • Remove the two screw marked in red.
    • Using the tweezers , pull out the metal bracket that holds the charging port in place.
    • Pull out the ribbon connector in orange.
    • Remove the one screw that holds the speaker in place.
    • Slowly pull out the speaker.
  6. Insert your new mother board with the 7 screws Reconnect all the connectors marked in red back to the mother board.
    • Insert your new mother board with the 7 screws
    • Reconnect all the connectors marked in red back to the mother board.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ethan Chow
회원 가입일: 2015년 09월 05일
1,806 평판
안내서 3개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 1,629
