주요 콘텐츠로 건너뛰기
LG G Pad 8.3 4G Back Panel Replacement
필요한 것
  1. LG G Pad 8.3 4G Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Back Panel Replacement: 2 단계, 이미지 1/3 LG G Pad 8.3 4G Back Panel Replacement: 2 단계, 이미지 2/3 LG G Pad 8.3 4G Back Panel Replacement: 2 단계, 이미지 3/3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
결론
Charlie Castorena
회원 가입일: 09/18/18
417 평판
안내서 3개 작성하였습니다
University of North Texas, Team S4-G3, Raign Fall 2018 University of North Texas, Team S4-G3, Raign Fall 2018 회원
UNT-RAIGN-F18S4G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 21
전체 시간: 416
