주요 콘텐츠로 건너뛰기
LG G Pad 8.3 4G Battery Replacement
필요한 것
  1. LG G Pad 8.3 4G Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Battery Replacement: 2 단계, 이미지 1/3 LG G Pad 8.3 4G Battery Replacement: 2 단계, 이미지 2/3 LG G Pad 8.3 4G Battery Replacement: 2 단계, 이미지 3/3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
  3. LG G Pad 8.3 4G Battery Replacement, Speakers: 3 단계, 이미지 1/2 LG G Pad 8.3 4G Battery Replacement, Speakers: 3 단계, 이미지 2/2
    • Remove the 4 1.5 mm screws holding the speakers in place.
  4. LG G Pad 8.3 4G Battery Replacement: 4 단계, 이미지 1/3 LG G Pad 8.3 4G Battery Replacement: 4 단계, 이미지 2/3 LG G Pad 8.3 4G Battery Replacement: 4 단계, 이미지 3/3
    • Put the spudger underneath the gold cap of the cable and lift to disconnect from device.
    • This cable can be damaged easily.
  5. LG G Pad 8.3 4G Battery Replacement: 5 단계, 이미지 1/1
    • Pull the cable back and out of the way of the speaker.
  6. LG G Pad 8.3 4G Battery Replacement: 6 단계, 이미지 1/2 LG G Pad 8.3 4G Battery Replacement: 6 단계, 이미지 2/2
    • Place the spudger in between the speaker and the device to pop the speaker out of place.
    • Pull the speaker out of the device.
  7. LG G Pad 8.3 4G Battery Replacement, Vibrator: 7 단계, 이미지 1/2 LG G Pad 8.3 4G Battery Replacement, Vibrator: 7 단계, 이미지 2/2
    • Remove the two screws on the white panel on the bottom right side.
  8. LG G Pad 8.3 4G Battery Replacement: 8 단계, 이미지 1/2 LG G Pad 8.3 4G Battery Replacement: 8 단계, 이미지 2/2
    • Remove the white panel.
  9. LG G Pad 8.3 4G Battery Replacement: 9 단계, 이미지 1/1
    • Remove the vibrator from the underside of the white panel.
  10. LG G Pad 8.3 4G Battery Replacement, Battery: 10 단계, 이미지 1/2 LG G Pad 8.3 4G Battery Replacement, Battery: 10 단계, 이미지 2/2
    • Remove the 3 silver 1.5 mm screws that remain.
  11. LG G Pad 8.3 4G Battery Replacement: 11 단계, 이미지 1/2 LG G Pad 8.3 4G Battery Replacement: 11 단계, 이미지 2/2
    • Remove the 2 black 1.5 mm screws.
  12. LG G Pad 8.3 4G Battery Replacement: 12 단계, 이미지 1/2 LG G Pad 8.3 4G Battery Replacement: 12 단계, 이미지 2/2
    • Insert metal spudger under the side of the gold strip and pull.
  13. LG G Pad 8.3 4G Battery Replacement: 13 단계, 이미지 1/2 LG G Pad 8.3 4G Battery Replacement: 13 단계, 이미지 2/2
    • Place spudger under the top of the gold bar and gently pry up.
  14. LG G Pad 8.3 4G Battery Replacement: 14 단계, 이미지 1/1
    • Pull on top of the silver block until gold bar lifts.
  15. LG G Pad 8.3 4G Battery Replacement: 15 단계, 이미지 1/1
    • Place spudger under the battery and run it around the edge to loosen it.
  16. LG G Pad 8.3 4G Battery Replacement: 16 단계, 이미지 1/1
    • Pull the battery out.
결론
Charlie Castorena
회원 가입일: 09/18/18
417 평판
안내서 3개 작성하였습니다
University of North Texas, Team S4-G3, Raign Fall 2018 University of North Texas, Team S4-G3, Raign Fall 2018 회원
UNT-RAIGN-F18S4G3
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I have followed your guide (LG G Pad 8.3 4G Battery Replacement) but what see when I pry off the screen is not what is on your pic of step 2.
It appears that I have to pry off the back panel to actually see the battery, the speakers and the gold cable.
How can I pry off the back panel?
Thanks,
Ed
Ed Miller - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 526
