주요 콘텐츠로 건너뛰기
LG G Pad 8.3 4G Speakers Replacement
필요한 것
  1. LG G Pad 8.3 4G Speakers Replacement, Back Panel: 1 단계, 이미지 1/1
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Speakers Replacement: 2 단계, 이미지 1/3 LG G Pad 8.3 4G Speakers Replacement: 2 단계, 이미지 2/3 LG G Pad 8.3 4G Speakers Replacement: 2 단계, 이미지 3/3
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
  3. LG G Pad 8.3 4G Speakers Replacement, Speakers: 3 단계, 이미지 1/2 LG G Pad 8.3 4G Speakers Replacement, Speakers: 3 단계, 이미지 2/2
    • Remove the 4 1.5 mm screws holding the speakers in place.
  4. LG G Pad 8.3 4G Speakers Replacement: 4 단계, 이미지 1/3 LG G Pad 8.3 4G Speakers Replacement: 4 단계, 이미지 2/3 LG G Pad 8.3 4G Speakers Replacement: 4 단계, 이미지 3/3
    • Put the spudger underneath the gold cap of the cable and lift to disconnect from device.
    • This cable can be damaged easily.
  5. LG G Pad 8.3 4G Speakers Replacement: 5 단계, 이미지 1/1
    • Pull the cable back and out of the way of the speaker.
  6. LG G Pad 8.3 4G Speakers Replacement: 6 단계, 이미지 1/2 LG G Pad 8.3 4G Speakers Replacement: 6 단계, 이미지 2/2
    • Place the spudger in between the speaker and the device to pop the speaker out of place.
    • Pull the speaker out of the device.
결론
Deja Morrow
회원 가입일: 09/18/18
109 평판
안내서 1개 작성함
University of North Texas, Team S4-G3, Raign Fall 2018 University of North Texas, Team S4-G3, Raign Fall 2018 회원
UNT-RAIGN-F18S4G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 145
