소개
If your rear facing camera is not working, it may be time to replace it. This guide will show you how to replace the rear facing camera.
필요한 것
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
이 단계에 사용된 도구:Magnetic Project Mat$19.95
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
Use a plastic opening tool to remove the camera, which is attached with adhesive to the front of the tablet.
거의 끝나갑니다!
결론
