주요 콘텐츠로 건너뛰기
LG G Pad 8.3 Speaker Replacement
필요한 것
  1. LG G Pad 8.3 Speaker Replacement, Back Panel: 1 단계, 이미지 1/2 LG G Pad 8.3 Speaker Replacement, Back Panel: 1 단계, 이미지 2/2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Speaker Replacement: 2 단계, 이미지 1/3 LG G Pad 8.3 Speaker Replacement: 2 단계, 이미지 2/3 LG G Pad 8.3 Speaker Replacement: 2 단계, 이미지 3/3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Speaker Replacement: 3 단계, 이미지 1/2 LG G Pad 8.3 Speaker Replacement: 3 단계, 이미지 2/2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Speaker Replacement, Speaker: 4 단계, 이미지 1/2 LG G Pad 8.3 Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
    • These screws are very small so make sure to keep track of them. You can use iFixit's Pro Magnetic Project Mat to help.
  5. LG G Pad 8.3 Speaker Replacement: 5 단계, 이미지 1/1
    • Use your fingers to remove the speaker.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Mario Salguero
회원 가입일: 09/14/15
781 평판
안내서 6개 작성하였습니다
CSU Fullerton, Team 1-6, Bruce Fall 2015 CSU Fullerton, Team 1-6, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G6
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,578
