주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G Pad F 7.0 Battery Replacement
필요한 것
  1. LG G Pad F 7.0 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Battery Replacement: 2 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  4. LG G Pad F 7.0 Battery Replacement: 4 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
결론
작성자
2다른 기여자 명과 함께
Matt Kloos
회원 가입일: 01/25/17
249 평판
안내서 2개를 작성함
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G5
3 회원들
안내서 10개를 작성함
1가이드 댓글
Pictures are all in focus and easy to follow
Jonah Basl - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 7
전체 시간: 899
