주요 콘텐츠로 건너뛰기
LG G Pad F 7.0 Battery Replacement
필요한 것
  1. LG G Pad F 7.0 Battery Replacement, Battery: 1 단계, 이미지 1/2 LG G Pad F 7.0 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Battery Replacement: 2 단계, 이미지 1/2 LG G Pad F 7.0 Battery Replacement: 2 단계, 이미지 2/2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Battery Replacement: 3 단계, 이미지 1/1
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  4. LG G Pad F 7.0 Battery Replacement: 4 단계, 이미지 1/2 LG G Pad F 7.0 Battery Replacement: 4 단계, 이미지 2/2
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
결론
Matt Kloos
회원 가입일: 01/25/17
249 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G5
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
Pictures are all in focus and easy to follow
Jonah Basl - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 13
전체 시간: 689
