주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G Pad F 7.0 Charging Port Replacement
필요한 것
  1. LG G Pad F 7.0 Charging Port  Replacement, Charging Port: 1 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Charging Port  Replacement, Charging Port: 1 단계, 이미지 2개 중 2개
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Charging Port  Replacement: 2 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Charging Port  Replacement: 2 단계, 이미지 2개 중 2개
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Charging Port  Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the top of the large orange ribbon cable.
    • Pry it off with the plastic opening tool as shown in the image.
  4. LG G Pad F 7.0 Charging Port  Replacement: 4 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Charging Port  Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the gyroscope (the blue rectangular cube) located near the bottom of the device with the plastic opening tool as shown in the image.
    • Remove the speaker located in the bottom right corner of the device with the plastic opening tool as shown in the image.
  5. LG G Pad F 7.0 Charging Port  Replacement: 5 단계, 이미지 2개 중 1개 LG G Pad F 7.0 Charging Port  Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the two screws located on the charging port as seen in the image using the Phillips screwdriver.
    • Using the tweezers, remove the orange ribbon cable along with the charging port.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Erik
회원 가입일: 01/25/17
293 평판
안내서 1개를 작성함
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G5
3 회원들
안내서 10개를 작성함
4가이드 댓글
Good work, Pictures are clear and easy to follow
Jonah Basl - 답글 공유
Just a minor item. On step 4 it tells you to remove the gyroscope, then remove the speaker. On on the unit I worked in you had to remove the speaker so you could get remove the gyroscope. I was working on the 8.0 instead of the 7.0 model, so perhaps that accounted for the difference.
Alan Siebens - 답글 공유
Where do you buy the new charging port you need to put in? It's like gold lined teeth top and bottom.
Stands For Jesus - 답글 공유
Also on his LG can we turn it into a prepaid monthly service if we get a at&t sim card kit or something similar?
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 14
지난 30일: 36
전체 시간: 4,356
